Is there a sunroof drain at the back of the sunroof?
Gimpin
Plant City, FL
I keep getting water on the floor of my galant ... I have checked the 2 drains at the front of the sunroof and I know they work. But my car is often parked on an incline so the water flows to the back. Is there a drain I didnt see at the back of the sunroof?
Gimpin
Plant City, FL
I've looked and dont see any ... there is just a large gap where the Sun roof slides in ... it looks like it is designed to drain to the sides but not sure where from there ... is there any way I can check or clear the drains?
Near Seattle, Washington
Unless i'm mistaken, i seem to recall a tube running down each C pillar from the rear corners of the sunroof tray.
blacksheep
Urbandale, Iowa 50323
^^^ yep, I think they run into rear fender wells or something...I cannot remember but there are 2 rubber lines.
OP - Are you certain roof is shutting fully or have no damaged moldings. I may have missed where the water is collecting. If its up front on passenger side wheel well, its under the cowling or something, else heater core pissing...
Barnes
Richland, WA
Quoting mitsuturbo:
You are correct.
blacksheep
Remove C pillars and look under headliners? I remember when I stripped a black vr4 I saw them. Else, remove trunk panelling and look into the sides. They may be clogged or something...If I remember they came into the sides of the trunk and attached to tubes that draned out...this is going off fuzzy memory from 4 years ago...Else, thats the way it was on my Evo...Damn it, I am bcoming Ken Inn.
My sunroof is an aftermarket one by ASC. The drains are exactly where guys say it is. My sunroof leaks because I need a new
gasket for the top. The leak messed up my headliner. One day I'll get that fixed. Mean while, I used blue tape to keep the rain out. It works.
